mslewis620 Posted October 22, 2016 Share Posted October 22, 2016 Far into my existing floor plan - just found out that one dimension on the survey is off nearly 4.5'. The family room end of the house was an addition that has odd angles. I finally called the surveyor after measuring the house 3 times. I need to manipulate about 25% of the first floor and change the angle as well to make it work out. Any recommendations on the easiest way to accomplish this or should I just delete that area and start over. Every room in this house is at a different elevation with varying ceiling heights so I hate to go backward. Link to comment Share on other sites More sharing options...
lbuttery Posted October 22, 2016 Share Posted October 22, 2016 you could try using the "edit area - all floors" tool Lew Link to comment Share on other sites More sharing options...
mslewis620 Posted October 22, 2016 Author Share Posted October 22, 2016 Here's the survey so you can see the angle. 10233 Inwood Road Corrected Survey copy 2.pdf Link to comment Share on other sites More sharing options...
ShaneK Posted October 22, 2016 Share Posted October 22, 2016 Post the plan Link to comment Share on other sites More sharing options...
mslewis620 Posted October 22, 2016 Author Share Posted October 22, 2016 Used edit area tool and seems to have kept everything I need except one small wall where it joined. Thanks! Link to comment Share on other sites More sharing options...
