capitaldesigns Posted October 17, 2016 Share Posted October 17, 2016 I am working on plan check corrections that will require me to add another sheet to the plans. I want to add a sheet numbered 8.1. All the current sheets are numbered 1 -12. I want this new sheet to fall just behind sheet 8 since the new sheet will be related to sheet 8. Is there a way to do this? Thanks, Mike Link to comment Share on other sites More sharing options...
Northriver Posted October 17, 2016 Share Posted October 17, 2016 Click the inset sheet after or before tool. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 17, 2016 Share Posted October 17, 2016 Pretty sure if you are using auto-page-numbering you cannot get an inserted page to go dot 1. But if you do not auto number you can number your inserted page anything you want. Link to comment Share on other sites More sharing options...
BrownTiger Posted October 17, 2016 Share Posted October 17, 2016 Insert a new page after 8.0, open properties and set the "page label" to "A8.1". Alternatively you can try typing "#.1" Auto numbering will still work with the rest of your pages Link to comment Share on other sites More sharing options...
