PDF shaded grey?
ACADuser
In a plan, can't load it at this time, I insert a PDF & scale it.
While selected it displays as faded & shaded grey.
But when un-selected it remains grey.
I have to close X7 & reopen for it to turn white.
Is there a way to un-select so I don't have to shut X7 down?
You can see the new walls I added but the PDF grey's out all
The PDF has a white background.
I did find that if you draw a wall & then use UNDO that will reset the PDF from grey to white.
Must be some sort of bug that leaves the PDF grey when you insert it & then scale it.
If it never happen to you it may be something in my computer that is not playing well with CA.
Alan,  There are a couple of things that have been mentioned for situations like that to bump the program.  The one that I can remember is to hit undo and then redo but there are two or three other moves that do a similar thing that I have forgotten.
