capitaldesigns Posted October 7, 2016 Share Posted October 7, 2016 How do I set the temporary dimensions to locate the edge of the doors and windows rather than center to center ? Thanks, Mike Link to comment Share on other sites More sharing options...
glennw Posted October 7, 2016 Share Posted October 7, 2016 The temp dims use the current dim defaults. So open the current dim defaults dbx...Locate Objects panel...Openings...check Centers and uncheck Sides. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 7, 2016 Share Posted October 7, 2016 Pictures are better but now you have both. Nice Glenn, I also read that backwards the first time. Link to comment Share on other sites More sharing options...
capitaldesigns Posted October 7, 2016 Author Share Posted October 7, 2016 Thanks Glenn and Chopsaw. I would have thought that the temporary dimensions defaults for door and windows would also been placed under temporary dimension defaults. I wonder why they did not. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 7, 2016 Share Posted October 7, 2016 Yes me too. That is the only reason you had to ask. Maybe X9 Link to comment Share on other sites More sharing options...
glennw Posted October 7, 2016 Share Posted October 7, 2016 The quickest way to get to the current dimension defaults is to double click a dimension tool - as long as Edit Active Default on Double Click is checked in Preferences, which I think it is by default. Link to comment Share on other sites More sharing options...
