DCB123 Posted September 22, 2016 Share Posted September 22, 2016 Chief users; I have a home model which I am not free to share with you, but really need some help getting the materials to work out separately and correctly in the 3 back bedrooms on the left side of the house. The separate living spaces of the rest of the house, kitchen, living room, entry, are a different material of laminate by the way? So far I have tried almost everything, as I am somewhat frustrated, but not giving up. I've tried settings the program defaults, the floor defaults, in the structure tabs under each separate room that I want the material changed from the default material of laminate, to the material for the three bedrooms of the carpet. (please see attached floorplan definitions laminate and carpet picture) I have tried to change the default settings, the room definitions under the structure tab and many other ways and still no results in the 3D perspective views. Still doesn't work for me, please let me know what it is that I'm doing wrong here? Thx much! DCB Link to comment Share on other sites More sharing options...
jcaffee Posted September 22, 2016 Share Posted September 22, 2016 To get the default material you've defined to display in any given room, ensure the "Default" checkbox is selected under the Floor Finish of the Structure tab for that room. jon Link to comment Share on other sites More sharing options...
ShaneK Posted September 22, 2016 Share Posted September 22, 2016 Change here.......... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 22, 2016 Share Posted September 22, 2016 The Defaults apply to all new rooms you create. To change the Floor Material of any Room to be different you have to select the Room and open the dbx. Then in the Structure Tab make the change to the "Floor Finish". Link to comment Share on other sites More sharing options...
