Designer100 Posted September 16, 2016 Share Posted September 16, 2016 I would appreciate any help in getting the greatroom/dining area bar floor showing up? cannot do elevation in that area either. shows hole in floor. Thanks, Walker.Patrick bar.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 16, 2016 Share Posted September 16, 2016 I downloaded your .plan file and found NOTHING WRONG at all what so ever. Whether an overview, doll house or elevations, they all look just fine. The "the great room/dining area bar floors" also look fine on my PC. DJP Link to comment Share on other sites More sharing options...
pintodesign Posted September 16, 2016 Share Posted September 16, 2016 I just took a quick look... Some of your walls are designated as "no room definition" Change that, and adjust your floor and ceiling heights to whatever you need. HTH Barb Link to comment Share on other sites More sharing options...
Designer100 Posted September 17, 2016 Author Share Posted September 17, 2016 The Bar area has foundation and floor missing in the middle of it and you can not make a wall elevation of that wall either of the millwork? In perpective you can turn it around and it shows foundation hole in it looking from the bottom. I cannot fix it. Link to comment Share on other sites More sharing options...
ShaneK Posted September 17, 2016 Share Posted September 17, 2016 Downloaded plan and opened it up. As DJP said "it's all there". Link to comment Share on other sites More sharing options...
