Changing Blocked Asbuilt CAD Detail Sometimes Changes ratio of block? Anyone else getting this?
zowie123
Hi,
It seem to have been happening in v8 more than before.
I can usually change the ratio back to 1 to 1, but now the block won't unblock...
Weird blocking behavior has happened several times this year.
Just checking to see if it's a known glitch,
Thank you,
Barry
Barry,
Yes, I experienced this quirky behavior just yesterday.
I had created a block made up of some 3D primitive shapes (polysolids).
When I tried to copy and paste the block it was jumping about and changing shape.
I had to explode the block, copy and paste the primitives and then re-block.
As stated in the Reference Manual when you resize a CAD block or symbol block using the edge handles you afterwards cannot unblock the CAD block or Symbol block.
However if you use the corner handles to resize the blocks then you can block and unblock them after relationally resizing them.
