SketchArchitect Posted August 24, 2016 Share Posted August 24, 2016 Hi All, Anyone know why my layout PDF's are now 10 to 13 MB instead of under 1MB? Did X8 change something? thx Stu Link to comment Share on other sites More sharing options...
ShaneK Posted August 24, 2016 Share Posted August 24, 2016 This post has info https://chieftalk.chiefarchitect.com/index.php?/topic/10727-merging-pdf-pages-into-a-layout/ Link to comment Share on other sites More sharing options...
SketchArchitect Posted August 24, 2016 Author Share Posted August 24, 2016 This post has info https://chieftalk.chiefarchitect.com/index.php?/topic/10727-merging-pdf-pages-into-a-layout/ Thank you - that link is referencing importing PDF elements INTO a layout... I'm not doing that; I'm talking about a pure CAx8 file saving as a PDF. Link to comment Share on other sites More sharing options...
Kiwideziner Posted August 24, 2016 Share Posted August 24, 2016 What resolution are you using?? check your print DBX settings Link to comment Share on other sites More sharing options...
ShaneK Posted August 25, 2016 Share Posted August 25, 2016 Once you print your pdf from CA, shrink size of file with pdf editor. Link to comment Share on other sites More sharing options...
rlackore Posted August 25, 2016 Share Posted August 25, 2016 I haven't noticed any difference in PDF file sizes with X8. Check your DPI settings in the Print View dbx. Maybe images or embedded PDFs within the Chief Plan file will increase the output PDF file size? I'm just guessing. Link to comment Share on other sites More sharing options...
