How to add window bars (security) ?
Arcade
Add lites in the widow dbx. or if that is some thing you can't achieve using lites, try loading custom muntins. custom muntins can be loaded as a cad block having the shape you desire and then load as. custom muntins(refer the help & ref manual for further info). if that doesnt work there is still a way to add window treatments. in window dbx, go through the window treatments and look at the options you have.
