Sign in to follow this
Arcade
How to add window bars (security) ?
Add lites in the widow dbx. or if that is some thing you can't achieve using lites, try loading custom muntins. custom muntins can be loaded as a cad block having the shape you desire and then load as. custom muntins(refer the help & ref manual for further info). if that doesnt work there is still a way to add window treatments. in window dbx, go through the window treatments and look at the options you have.
I would do that with a molding polyline with a molding added for each section.
That way, they will all stay together as one assembly which you can move around and stretch to suit various width openings.
Thank you for the answer, i'll try the different solutions tonight and give you feedback.
    27465
    SuzLeigh
    SuzLeigh
