Sign in to follow this
Tricia
Dimension transparency
I am trying to make my dimensions transparent, as now the "box" around the numerals is white and blocks the details of the plan behind them. There seem to be quite a few text dialogs that allow me to change the fill, but I can find nothing for the fill on dimensions. Where can I go to make this change?
Hi Tricia, Open your dimension line and try this. Unfortunately this is for all the dimensions unless you make a copy of your Default.
Or, if you want to do it directly in the dimension default, you can select Use Custom Text Style and then Transparent.
This sets the Text Style directly with the dimension default and doesn't rely on a separate text style to set the dimension text.
I have all my dimension default text styles setup like this.
    27486
    Camian
    Camian
