Wall material region causing floating outlets on other side of wall
slowrolls
Go to solution Solved by Alaskan_Son,
ive attached 2 pictures, first being one that i added a wall material region on the outside of the house (did this to show you the problem).
the 2nd picture is on the inside and the light switch appears to be floating away from the wall.
if i delete the wall material region (the rectangle outside of the house), the light switch goes back to the wall as normal.  is this a bug or normal behavior?  if so, what am i doing wrong?
version X8
  • Solution
I can easily reproduce in a new plan.  Definitley looks like a bug to me and should be reported to tech support.  In the meantime, try using a cabinet mounted outlet.  The ones in Chief's library don't behave all that well though so if you want you can get some better, slightly modified versions of the same in this thread...
https://chieftalk.chiefarchitect.com/index.php?/topic/7955-improved-cabinet-outlets/?hl=outlets
