lbuttery Posted May 20, 2016 Share Posted May 20, 2016 I have the layout setup for 11 x 17 landscape the layout looks good the PDF looks good yet when I print to 8.5 x 11 it's not right (see attached) each of the maps should still be in the corners ??? I have checked layout settings and PDF settings and I can't see what is causing the mis-print I have other 11 x 17 layouts and they work fine ??? Lew NICHOLS_TOURS_160519_1215_LBX6.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 20, 2016 Share Posted May 20, 2016 That's not going to work like you're imagining it should Lew. 8.5 X11 and 11x17 are 2 different ratios. Link to comment Share on other sites More sharing options...
lbuttery Posted May 20, 2016 Author Share Posted May 20, 2016 Michael: wow, I just went over my other PDF's and I could have sworn they were printing to the edges when doing 8.5 x 11 from 11 x 17 PDF man, I need new glasses or a new brain thanks for looking Lew Link to comment Share on other sites More sharing options...
English Posted May 20, 2016 Share Posted May 20, 2016 Glasses are cheaper than brains. Alan Link to comment Share on other sites More sharing options...
lbuttery Posted May 20, 2016 Author Share Posted May 20, 2016 as a followup I tested 18 x 24 and that printed nicely on 8.5 x 11 I started with the larger size as I wasn't sure the stuff would be readable on 8.5 x 11 it is - so I set the drawing sheet to 8.5 x 11 and adjusted the maps - reads fine 8.5 x 11 is much cheaper to print when doing 100 copies for 8 pages of info going to look for new glasses now Lew Link to comment Share on other sites More sharing options...
