Sign in to follow this
lbuttery
8.5 X 11 Misprint
I have the layout setup for 11 x 17 landscape
the layout looks good
the PDF looks good
yet when I print to 8.5 x 11 it's not right (see attached)
each of the maps should still be in the corners ???
I have checked layout settings and PDF settings
and I can't see what is causing the mis-print
I have other 11 x 17 layouts and they work fine ???
Lew
NICHOLS_TOURS_160519_1215_LBX6.zip
That's not going to work like you're imagining it should Lew. 8.5 X11 and 11x17 are 2 different ratios.
Michael:
wow, I just went over my other PDF's and I could have sworn
they were printing to the edges when doing 8.5 x 11 from 11 x 17 PDF
man, I need new glasses or a new brain :(
thanks for looking
Lew
as a followup I tested 18 x 24 and that printed nicely on 8.5 x 11
I started with the larger size as I wasn't sure the stuff would be readable on 8.5 x 11
it is - so I set the drawing sheet to 8.5 x 11 and adjusted the maps - reads fine
8.5 x 11 is much cheaper to print when doing 100 copies for 8 pages of info :)
going to look for new glasses now :)
Lew
    27478
    Oilersfan20
    Oilersfan20
