English Posted May 10, 2016 Share Posted May 10, 2016 I'm trying to explode a block I made but get a message saying it cannot be exploded because the X Y scaling are different. Is there anyway I get around this?ThanksAlan Link to comment Share on other sites More sharing options...
Solution BrownTiger Posted May 10, 2016 Solution Share Posted May 10, 2016 Drug the block from library into your plan. Explode it immediately, prior to resizing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 10, 2016 Share Posted May 10, 2016 I'm trying to explode a block I made but get a message saying it cannot be exploded because the X Y scaling are different. Is there anyway I get around this? Thanks Alan Open the block and change the size factors to 1.0 and 1.0. Note: I'm not at my computer to test, but other size factors might work as well so long as they match each other (.5 and .5, .2 and .2, 2.0 and 2.0, etc.) . Link to comment Share on other sites More sharing options...
English Posted May 10, 2016 Author Share Posted May 10, 2016 Michael the current height and width are 162" and 272 13/16". If I change the width to 162" it screws up the ration. Alan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 10, 2016 Share Posted May 10, 2016 Don't change the actual width or height. Just the "Size Factor"...and once you explode the block you can change it back to whatever you want. Link to comment Share on other sites More sharing options...
English Posted May 10, 2016 Author Share Posted May 10, 2016 Drug the block from library into your plan. Explode it immediately, prior to resizing. I added it to my library and then brought it back in and can now explode it. Thanks Alan Link to comment Share on other sites More sharing options...
MickeyToo Posted May 11, 2016 Share Posted May 11, 2016 I added it to my library and then brought it back in and can now explode it. Thanks Alan That is because when you added it to the library the block's scaling factor reverted to what it was when the block was created (the block you sent to the library and the one you pasted back in the plan were different sizes). This is another way of doing what Michael suggested. Link to comment Share on other sites More sharing options...
English Posted May 11, 2016 Author Share Posted May 11, 2016 Thanks guys Alan Link to comment Share on other sites More sharing options...
