timmy123 Posted April 1, 2016 Share Posted April 1, 2016 Hi all, All of a sudden I am having issues with my layout. Whenever I send things to my layout they don't show up correctly see attached layout file and image. It appears that there is something which moved to layout but is not showing up (see screenshot). I can select it and when I click it I go to the original view/plan, but it is not showing up correctly in layout. Please let me know if you have any hints. thanks, Tim Issue.layout Link to comment Share on other sites More sharing options...
timmy123 Posted April 1, 2016 Author Share Posted April 1, 2016 Also attached is the plan which shows the issue when I send to layout. testplan2.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 1, 2016 Share Posted April 1, 2016 A layout without any associated plan file will by default be blank. DJP Link to comment Share on other sites More sharing options...
timmy123 Posted April 1, 2016 Author Share Posted April 1, 2016 Hi David, Thanks a lot. Could you please elaborate, since it is not working even though I specified the plan file. Link to comment Share on other sites More sharing options...
glennw Posted April 1, 2016 Share Posted April 1, 2016 Timmy, You have an object in your plan that is causing the problem. It is "Silhouette_Woman_Talking" on the "Fixtures, Interior" layer. For some reason it is very, very, very wide. What you are seeing in the layout is a correspondingly wide Layout Box to accommodate it. Delete it and all should be good. Is it something you imported from Sketchup? You can see it and select it in a 3D view. I am not sure why it is behaving like that, but it is definitely corrupted and deletion is the best action to take. Link to comment Share on other sites More sharing options...
timmy123 Posted April 1, 2016 Author Share Posted April 1, 2016 Thanks Glen and David, Indeed it was the woman causing issues. I think I brought it in from Sketchup log time ago. It is interesting because I had other copies of the woman and they were fine. I just deleted this particular one to fix my house ! Link to comment Share on other sites More sharing options...
