Issue With DWG & DXF Import
English
My contractor has an inexpensive CAD program Viacad 3d v9 and he says he draws everything at full size (as he should) but when he sends me a DWG or DXF file it imports at a scale (that I have yet to determine).  Any idea what is happening as I don't want to have to scale everything before converting the lines to walls?  He says that he goes to Files>Export>DWG.
Thanks
Alan
I got a dimensions and it seems as if it's 1" = 10' as a wall that measures 2'-6" should be 30'  However when I scale the drawing I'm not getting what I want and I'm having a brain freeze. :)  What should I scale up to get to a full size?
Thanks
Alan
I must have been having a senior moment as it was obvious that it should be x12 -- 30" = 30' so 1" = 12".
Alan
BTW I found out that his CAD software will not let him draw full size -- it defaults full size to I' = 1".  I've always been taught that you draw full size and only scale to print.
