GoojDesign Posted March 21, 2016 Share Posted March 21, 2016 Hello everyone, I haven't been able to find a simple way of clipping a column to fit against a wall. In Autocad I would usually clip it at 4/5ths of the size for the visual effect of the column against the wall. In Chief it seems to snap against the wall which would leave me with a gap between the column & wall surface. Am I missing something on this or do I need to build each one of these manually from scratch? Thank you! Link to comment Share on other sites More sharing options...
Solution HumbleChief Posted March 21, 2016 Solution Share Posted March 21, 2016 Hold the cntrl key and place the column wherever you like? Link to comment Share on other sites More sharing options...
GoojDesign Posted March 21, 2016 Author Share Posted March 21, 2016 Thank you so much, I thought it was simple... just couldn't find it. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 21, 2016 Share Posted March 21, 2016 As above or uncheck Bumping/Pushing, same thing. You can place any object anywhere, just be aware that there are times when the object may cause or behave not as expected. If for example there is a floor height difference on each side of a wall and you place an object that projects into that wall it's height from the floor may lock onto the other floor height. You may need to manually adjust the objects height from floor. Graham Link to comment Share on other sites More sharing options...
