Chris50 Posted March 18, 2016 Share Posted March 18, 2016 Hello, How do I turn my stair railing to cable railing to match my other railings????? I am using x7 Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 18, 2016 Share Posted March 18, 2016 You cannot do it via the stair dialog, the way I do it is to draw a cable railing wall, marked "follow stairs" and turn off the railing of the stair object on the rail side of the stairs. It is not "easy" to do but can be done with patience and exactness. DJP Link to comment Share on other sites More sharing options...
ACADuser Posted March 20, 2016 Share Posted March 20, 2016 More on the subject: https://chieftalk.chiefarchitect.com/index.php?/topic/3493-wall-under-stair-disappears-when-railing-is-added/#entry29933 Link to comment Share on other sites More sharing options...
2wheeltodd Posted March 21, 2016 Share Posted March 21, 2016 Try turning off railings on the stair DBX and manually draw a railing on the stair. Make it a panel in the rail DBX and select your cable rail from the lib. Link to comment Share on other sites More sharing options...
