Sign in to follow this
jodilynn73
Newbie - Can I Manually Add A Gutter?
I'm working on my first plan in Chief Architect.  I am struggling with roof planes, but finally have them ironed out it seems, except for the front porch.  I'd like to remove the section of gutter under the porch roof, but only see the option of removing it from the entire roof plane.  I need a big pink eraser.
Unlock and display the gutters layer and then click on that segment and click "No Moulding On Selected Edge".
What Michael said.... He's getting very fast with the responses.  ;)
Sadly, the gutter rebuilds itself without much prompting. I have reported this a number of times with very little joy. It sometimes is better to leave the gutter off entirely and explicitly create a molding polyline with a gutter profile. This stays where you want it.
Curious, have you tested the behavior in X8 yet?
Never mind.  I just tested myself.  Still the same.
    27648
    DarrinKoone
    DarrinKoone
  • Similar Content
    • By ChristinoDesign
      We're trying to figure out how to change the angle of pendent lights on vaulted ceilings. When we create the ceiling angle, the lights follow and aren't angled properly. How do we change the lights so they go vertical rather than at a tilt?
    • By Alyssa5
      Hi,
      I am using Chief Architect X8 on a Mac.
      I am having trouble with roof planes - I want to be able to change the baseline height but it keeps defaulting back and won't alter.
      Yet when I open the same file on another computer I can change it
      Any suggestions?
      Thanks
    • By josiemlittle
      Hello, I’m needing help lowering the roof. I’m trying to make a 50x80x16 shop with the pitch lower than the default gable height. I’m new to this and I’m hoping this software will help build our dreams on our farm. I want the look of the attached photo with the front being the 80 ft side.
    • By amydutton
      How do I put a roof return on this roof? Can't find a video about it anywhere on the Chief Website... is there another name for it?
      See attachment, and where I drew in black.
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
