tandrasz Posted December 5, 2015 Share Posted December 5, 2015 Hi, I'm new to this. I'm using Chief Architect Premier X7. I have imported perimeter and elevation data from a DWG file. It looks correct in the Perspective Full Overview, however when I try to draw a retaining wall all I get is something that looks like a stripe of concrete on the ground (attached) - the terrain does not get broken. In a new plan with perimeter and elevation lines created manually retaining walls work as expected. What am I missing? Tom Here is my plan: Terrain_good2.plan Link to comment Share on other sites More sharing options...
dshall Posted December 5, 2015 Share Posted December 5, 2015 Hi, I'm new to this. I'm using Chief Architect Premier X7. I have imported perimeter and elevation data from a DWG file. It looks correct in the Perspective Full Overview, however when I try to draw a retaining wall all I get is something that looks like a stripe of concrete on the ground (attached) - the terrain does not get broken. In a new plan with perimeter and elevation lines created manually retaining walls work as expected. What am I missing? Tom Screen Shot 2015-12-05 at 7.08.28 pm.png Here is my plan: Terrain_good2.plan The plan you posted has no retaining wall Link to comment Share on other sites More sharing options...
tandrasz Posted December 5, 2015 Author Share Posted December 5, 2015 It has, but it looks like a U shaped stripe on the surface - like in my screenshot. Try creating one in that plan. Link to comment Share on other sites More sharing options...
Mark3D Posted December 5, 2015 Share Posted December 5, 2015 You need to adjust your terrain elevation data like it needs to be different on each side of the retaining wall so break your elevation lines on the lower level area and adjust the heights as needed https://dl.dropboxusercontent.com/u/29819538/Terrain_good2.plan Link to comment Share on other sites More sharing options...
tandrasz Posted December 5, 2015 Author Share Posted December 5, 2015 @dshall - sorry Scott - I posted the original plan - without the retaining wall. @mark3D - thanks Mark, I will break elevation lines. Link to comment Share on other sites More sharing options...
Solution dshall Posted December 6, 2015 Solution Share Posted December 6, 2015 ......I will break elevation lines. Elevation lines do not need to be broken. If you use an elevation region, that elevation region will override the elevation lines.... much quicker Link to comment Share on other sites More sharing options...
tandrasz Posted December 6, 2015 Author Share Posted December 6, 2015 Thanks Scott! I'm getting much better results with the elevation region, but I still must be doing something wrong. Here is the screenshot of mine (lower) vs Mark's (upper): Mine has these rugged terrain irregularities, while Mark's is smooth. The plan: Terrain_good2.plan Link to comment Share on other sites More sharing options...
dshall Posted December 6, 2015 Share Posted December 6, 2015 Thanks Scott! I'm getting much better results with the elevation region, but I still must be doing something wrong. Here is the screenshot of mine (lower) vs Mark's (upper): Screen Shot 2015-12-07 at 6.14.30 am.png Mine has these rugged terrain irregularities, while Mark's is smooth. The plan: Terrain_good2.plan Move your elevation region UNDER THE WALL BY ABOUT 3 inches, that should take care of irregularities. Link to comment Share on other sites More sharing options...
tandrasz Posted December 6, 2015 Author Share Posted December 6, 2015 That worked great! Now, I just need to figure out how to convert the elevation region square into a polygon, so I can get rid of the up bump in the bottom right corner. Link to comment Share on other sites More sharing options...
jcaffee Posted December 6, 2015 Share Posted December 6, 2015 Line Break tool jon Link to comment Share on other sites More sharing options...
tandrasz Posted December 7, 2015 Author Share Posted December 7, 2015 Thanks - broke the right border at the start of the retaining wall and then made the shorter part almost zero length. Link to comment Share on other sites More sharing options...
