Disappearing Floor System And Room Specifications.
jon_guiffre
Go to solution Solved by jon_guiffre,
I made changes to a design by reducing the room sizings, when I did this I lost the Room Specification for the room and lost the floor system to the room. I aligned the foundation walls and 2nd floor walls to the 1st floor layout. Now I cannot regain the Room Specification for these rooms and there does not seem to be any help from the manual. Is there an easy fix that I'm just not seeing or do I have to start from new?
Steve J
CA X7
iMac OS X Yosemite 10.10.5
2.9 GHz Intel Core i5
8GB 1600MHz DDR3
post-3961-0-45516400-1448650510_thumb.png Plan B.zipFetching info...
  • Solution
Thanks for giving me direction. The walls were spec'd as No Room Def. When I reduced the floor plan I just moved walls, it seems CA has some weird results that don't seem to logical, but just change on their own. It makes for a confusing program.
Thanks again!
