T-Square Posted November 25, 2015 Share Posted November 25, 2015 Hello, Thanks to anyone that can help me with this. Yes, I know both my versions of software are very old. Just can't afford the upgrades at this time. I am trying to take a 3D object I create in AutoCAD v2011 and bring it into Chief v10.08b. Again, yes, I know older versions. Hopefully someone had this issue some time ago and can help me figure it out. I can get as far as the select object in the "Symbol Wizard, it accepts the dwg version and all, but I don't get the "next" button highlighted. I heard of using the 3dsout command, but that is not available in 2011 and the updated "arx" only goes to 2009 I believe. I have tried saving in all the previous versions available in the saveas and dxf's. Any help is apprecaited. Thank you. Tim Link to comment Share on other sites More sharing options...
lbuttery Posted November 25, 2015 Share Posted November 25, 2015 Tim: you will need someone to volunteer to import the autocad 2011 file and then save it to a version of autocad that Chief ver 10 can use - probably around 2004/5 you might be able to do a google search and find a free utility that can convert an autocad file to an older version Lew Link to comment Share on other sites More sharing options...
lbuttery Posted November 25, 2015 Share Posted November 25, 2015 Tim: BTW: I have tons of ver 10 and 9.5 training material and cad collections and library collections if you live anywhere near driving distance of Buffalo NY way too much stuff to mail Lew Link to comment Share on other sites More sharing options...
imodel Posted November 26, 2015 Share Posted November 26, 2015 AutoCad --> .dxf --> Accutrans --> .obj --> v.10 Accutrans being the file converter and .obj is best format to import to v.10. HTH. EDIT: Also, Blender has add-on to import .dxf if you are comfortable with that app. Sketchup Pro can maybe do the conversion too? Link to comment Share on other sites More sharing options...
