Designer100
Can anyone help with my stair not showing up on ground level from basement . I made foundation as basement (existing). Stair existing only 9'6" ;long. Basement  level stair is not showing up thru floor  top level .
This is small apartment. Bldg is exist basement and top level all open inside and I designed small apt.  8' clg in basement. This is going out of state and someone sent me measurements. for top floor and basement.
Thanks for any help.
Newell Cheatheam
www.newellsdesigns.com
newell.cheatheam@gmail.com
281.392.3034
ca x7
Apartment.plan
A couple things...
1.   You can select that room you created above the stairs and make the room type "Open Below" and your stairs will show up.  If all you're producing is floor plans, that might be enough, HOWEVER...
2.   Bigger issue is that your stairs don't actually work as you've drawn them up.  Take a section view midway through your stairs and parallel with them and you'll see what I'm talking about.  They just need to be adjusted and then you don't need that manually created room on the main floor necessarily, the auto stairwell tool would do the trick.
Thanks for the help Alskan_Son. Yes I know about the stairs. Said existing and only 9'6" long. Something wrong with that. I went on and made it longer like it is surpose to be and sent to client in Tenn. Hall I was doing was floor plan design, power, electrical, and interior elevations. stair and hull of bldg existing.
The problem is that the 9'6" stairs would not reach the floor above.  By opening the stair dbx you can edit the treads & risers so that it will reach (not a legal stair but it would make the "stairwell" tool work).  Chief just needs the stair to reach the floor above in order to cut out a stairwell.
    31608
    FireflyHomes
    FireflyHomes
  • Similar Content
    • By Thewoodmaster
      I cant for the life of me get the two inside mitered 45 corners to connect the stairs together, or get the small section by the wall to even draw the stairs.  I also cant get the direction of the grain on the deck boards to run the right way.  I tried copy the material and rotate it, but no luck.  The stairs are just pissing me off at this point.  Also why are the treads showing up as a single tread and not 2 deck boards.
      patio plan.plan
    • By Meltdown00
      Is it possible to model this in CA? (Reasonably close.) How would I do it?
    • By DRyeHD
      I've tried all dbx setting combinations I can think of, looked through the discussion topics, and on the FB user group - can't find a solution to get my balusters to go down to the stair treads.  I see a few pictures of this type of application but can't figure out how to do it.  I turned the auto-rail off and am using the railing tool.  Any help with this is appreciated.
    • By KDsnyder
      I have a building which has a staircase outside of the structure that I'd like to display on the second floor plan. Is there a way to do this without creating walls under the stairs or encasing the area with invisible walls? Thanks!
    • By HCremodel
      I have needed tom place stairs that go through a doorway on multiple occasions, and every time I try it would seem the program glitches and usually breaks the wall or the doorway so you can see the structural materials. The best solution I have found was placing two staircases on either side of the opening, but even that solution isn't perfect. Has anyone found a solution to this?? Am I doing something wrong? I feel like it's pretty common for stairs to go through openings, so it would seem odd to me if chief would not have an option for that.... I attached a picture of what I am encountering. I am using premier x13 beta, but this was also a problem in x12
