OkcDesigner Posted November 6, 2015 Share Posted November 6, 2015 Can anyone tell me how to do a dimension with out the dimension number? I like to dimension roof plt. hts. like attached picture. using text and arrows works how ever you can not bring them together or turns into one long arrow with out breaks at changes of plt. hts. Link to comment Share on other sites More sharing options...
joey_martin Posted November 6, 2015 Share Posted November 6, 2015 Draw a line and open the DBX. Add arrows to each end of it. Link to comment Share on other sites More sharing options...
OkcDesigner Posted November 6, 2015 Author Share Posted November 6, 2015 I tried your approach. time consuming. all so if you move the arrow lines closer then the arrow lines turn into one line again. There should be a way to do this. Oh great gurus.. Link to comment Share on other sites More sharing options...
joey_martin Posted November 6, 2015 Share Posted November 6, 2015 If there are multiple segments, you need to draw the line across all the segments, open the line and check the arrows at each end, then simply double click the break line tool and start breaking the segments into multiple pieces. The arrow at both ends will then adjust to the new segment lengths. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 6, 2015 Share Posted November 6, 2015 You can also change the dim text size to 1/16 and you won't see it. Link to comment Share on other sites More sharing options...
Solution OkcDesigner Posted November 20, 2015 Author Solution Share Posted November 20, 2015 Ok Perry, I expanded your idea to using another text style with white text and got this. Still have to put RTB for note but this is what I wanted. Joey, Perry, Great minds work alike. Thank You Link to comment Share on other sites More sharing options...
