johnny Posted October 7, 2015 Share Posted October 7, 2015 In layout I would prefer to see a white background to represent a clean paper appearance - and better judge my print results from that screen. Can I set a difference layout background from the main app? Link to comment Share on other sites More sharing options...
glennw Posted October 7, 2015 Share Posted October 7, 2015 Johnny, I don't think that you can have different background colors in plan and layout. BUT in layout you can go to File...Print Preview and check it on. This will give you white sheets for the printed page size which I think is what you are after. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 7, 2015 Share Posted October 7, 2015 In layout I would prefer to see a white background to represent a clean paper appearance - and better judge my print results from that screen. Can I set a difference layout background from the main app? Just to clarify... Are you using something other than a white background in plan? And if so, do you have "Show Drawing Sheet In View" checked in layout? Link to comment Share on other sites More sharing options...
johnny Posted October 7, 2015 Author Share Posted October 7, 2015 Just to clarify... Are you using something other than a white background in plan? And if so, do you have "Show Drawing Sheet In View" checked in layout? I'm using a grey background in plan just to make it easier on my eyes. The problem is that i have shades of grey I use for certain things and it was hard to tell how dark the shades where relative to printing on a white sheet. Also, I appreciate your suggestion Glenn, but I actually had figured a way to go around this by placing a large white rectangle around the sheet on "0"...so every page looks correct to me and white doesn't print. Thanks again! (below is example). Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 7, 2015 Share Posted October 7, 2015 You can also consider just going into preferences whenever you need to check things and temporarily changing your background back to white. Link to comment Share on other sites More sharing options...
glennw Posted October 7, 2015 Share Posted October 7, 2015 Johnny, Also, I appreciate your suggestion Glenn, but I actually had figured a way to go around this by placing a large white rectangle around the sheet on "0"...so every page looks correct to me and white doesn't print. Isn't that the same as Print Preview, but without having to manually place a white sheet? Print Preview is the tool that comes with Chief to do this. Link to comment Share on other sites More sharing options...
