X6 collada to lumion issues
inArtifex
   Is anyone having problems with the collada files exported from X6?
   I'm having issues related to texture: every time I have to import a .dae file from X6, my models lost the ability to generate shadows in lumion, and my textures are off scale.
  The work around has being: to send a .3ds file to sketch up and export as a .dae file from sketch up.
  Thank you all...
  I wonder if it could be related to the lighting in chief architect itself as because of the collada files properties.
  If you import a .3ds file from chief to lumion, it partially work, and .dae files from sketch up to lumion work perfectly. So it must be chief related.
  I got a open ticked right now, if I find something, I will get back to you...
Do you have an example of this?
I tried a couple of plans in Lumion free and couldn't see anything in the shading that seemed like it might be anything other than the rendering technique used by Lumion.
Also, textures seemed to map fine but in Lumion you need to import each material before it will be seen by the renderer.
 I have attached two example files, the example one: exporting directly from X6 and the the front perspective, exporting to sketch up first then exporting the .dae file again from sketch up. It's nothing related with the rendering technique, and the textures are automatically imported, when importing a collada file in Lumion...
Don't quite know what you mean above by importing each one.  And, I don't think they map right.  The scale of the texture is way off, which I think is shown by Kegles' example, and consistent with what I get.  I don't get the scale problem, or the shadow problem, when going via Sketchup, so it seems something is fundamentally different about the Chief .dae export vs. the Sketchup one.
  They were both created in chief architect, the difference is that: the example was exported from chief to a collada file and imported in to lumion.
  The sunny morning one, was exported from chief to a collada file, imported to sketchup (the .dae file from chief), exported from sketchup as a collada file also, then imported in lumion.
   Just to specify the process we have to go through...
Thank you for the examples.
And I see what Bryce means.
I didn't catch it before because I'm used to remapping textures and materials to models if they are exported out.
To see that Sketchup can retain this mapping though does seem to indicate a major difference in our exporters.
Thanks Kirk, it is good to get confirmation on that.  Going through Sketchup can be a real time killer because Sketchup does not seem to handle high face counts nearly as well as Chief does, so larger projects become incredibly tedious, often impossible, to get into Lumion effectively.  I hope you guys can find a solution for this.
  • 10 months later...
    32625
    Spartico
    Spartico
  • Similar Content
    • By YoderW
      Hey all,
      Is there a way to control what Chief names each material as it's importing a model as a collada (.dae) file?
      At my company, we use Chief to build the base model and then export as a collada file to import into Lumion to render. Lumion's latest version has the ability to automatically replace materials with "glass" or "water" in the name with those kinds of materials when importing, but for some reason Chief will randomly assign names to materials during the collada export process like "mat127-material," regardless of what they are named in the material settings. Other export processes will keep the material names, but those have their own problems in Lumion. The 3DS format, for example, is the best alternative, but it changes the scale of the model.
      I can't seem to find anywhere in the preferences to mess with export settings, though. It's nothing that totally breaks our workflow, as it only takes a couple seconds to replace the material, but it would be a nice little quality-of-life feature we could take advantage of if we could get Chief to cooperate.
    • By OnlineBuilder
      Im exporting my CA models to DAE, then converting them on Autodesk FBX converter on a Windows laptop. For some reason, the odd plan does not convert saying "not enough parameters". Its a pain because I can't start them again.
      I did some Googling and one solution was to convert the CA file to an obj, which you can't (Strange).
      Does anyone know why it is doing this? Is there another converter that works?
    • By OnlineBuilder
      Anyone using Simlab? The videos show a frame rate of around 2.5 fps. My fps rate is 0.05-0.1 fps. I exported from CA to DAE, then to FBX. Everything seems smooth and I am using a fast computer, but the rendering time is extremely slow.
    • By mrscott
      Notice it is not showing both XEON CPU's
