oldgreg
Adding masonry footer walls with slab foundation for rooms
I have an older ranch home and original plans for it.  See attached detail of the footer for load bearing masonry walls that act to support spanning trusses.  The living space is all slab foundation, but I cannot figure out how to get Chief to build regular foundation walls and then let us have a slab foundation as the floor for the rooms inside.
Imagine a rectangle house with footers for all the exterior masonry walls, a slab poured for the inside space, and a single interior load bearing wall on that slab.  The final detail would be exterior slabs for the patio and carport likely with their own structure entirely, not connected to the home.   I need to be able to show load bearing walls that are IN the slab with a standard internal slab turndown, awhile also having footer walls for the exterio masonry walls.  Having trouble combining everything.
Thanks for all the help!
I think marking the interior wall load bearing ,should add a Footing under it but if not add one on the foundation Tab for the wall.
I need to understand entirely how to build out the slab when I've already made all the exterior wall footer walls (not slab).  The program wants to build floor joists when I door foot walls.  If i go into each room and change the foundation to slab, then the footer walls go away and they become slab turndowns.
change the Default Floor structure   to 4" solid Concrete and delete the OSB subfloor layer , you need to setup all your defaults Before you start your drawing, as much as possible to match existing conditions , things such as Room heights, window and door types etc. .....Floor Joists and OSB are the OOB settings Chief Comes with.
Ahh!  Thanks Mick.  That did the trick for getting the floor poured.  I've been working the defaults as you suggested but must have overlooked this as it was pretty buried.
Any last advice on how to make that one interior wall have the standard interior load bearing profile with the chamfers and such that I was getting when I made the entire foundation a slab?
Here is a screenshot of what I am trying to do, with annotations.  Hope this helps clarify my troubles!  Please let me know how you'd approach this?
Post your plan so people can look at it and give better advice , What version are you using?
I've got the X7 version.  Here is a plan.  The redline I gave earlier should be helpful in showing how I am trying to mix all this together.  A final piece I am having trouble with also is getting the garage/carport in order.  That needs to be it's own monolithic slab with it's own footings...how in the world to get the chamfer type footings?  I only am able to get stem wall type footings on it.  Thank you for the suggestions and support.
shangri las copy.plan
The mixing is likely part of the issue ,you may have to do some of it manually , but because you have played with all the room settings, trying to fix stuff nothing is at default, so rooms wont take any settings from the Plan's defaults, I had to go to each room and mess with floor settings to get it to work as far as I got it.
The footing on the laundry wall was easily added on the wall's foundation tab , but I can't get it to show the chamfer.
You had the carport and front porch labelled Porch in the room def.  which is why I think you don't have a foundation there as Porch Rooms auto get a 4"Slab only.
shangri las copy_MH.plan
I may have misunderstood but I think he wanted a 8" stemwall and conc. 4" slab floor with thickenings under the load bearing walls eg at the Laundry and around the front Entry.
Think you did a mono slab right P. ?
Is that not what he wanted?
This is it!  How would I have done it going back to default?  I see that you did it, but I would like to learn how you applied the slab foundation to the edges of the carport while still tying them into the footer walls where they exist already for brick.  Mind stepping me through it?
Appreciated!
that is more or less automatic once you have the Carport and rear Porch setup for Monoslabs , I have played some more and the only way to get it all was to do stuff manually . like the footing only walls around the kitchen and the foundation wall under the carport and front entry...  it seems the Chamfer on foundations only works on Monoslabs not footings too, so you would have to fix that in section views, unless someone else knows how to get it to work.
here is the updated plan , I have saved cameras for you to open and look at , for eg. camera 10 shows some weird stuff around the rear porch walls , but I have never seen that effect before ...didn't think a slope topped wall was possible actually....
I setup a layerset (camera view-no walls) so you can see just the foundation and floor slab only so it's easier to see what's going on....not sure why the laundry wall footing doesn't show in some views but it is there in the Cross sections.
shangri las copy_MH2.plan
Just to be clear you can also add Slab footings as needed manually if needed(slab footing tool, see ref.manual) , though I didn't need them above, I did add the garage foundation stem walls manually since nothing I did would bring them back. I then deleted the internal stem walls and footings and added a footing to those walls only via the wall's DBX.
I think getting your defaults right and your room settings right  before building anything is important and seems to be bourne out in another thread today on foundations too.....https://chieftalk.chiefarchitect.com/index.php?/topic/6065-more-structure-dbx-challenges/page-2#entry53315
Hope this helps,
    27449
    DesignerPro2020
    DesignerPro2020
  • Similar Content
    • By Doug_N
      Any window opening in a masonry wall usually requires an angle iron lintel.  That seems to be a problem for CA.  Although there is a lintel option for windows, you have to do the lintel manually or create a profile for it.  The lintel doesn't show up correctly in the window schedule if it is an angle, i.e. 3 1/2 x 4 x 1/4 LLV (long leg vertical.)
      Does anyone have a workaround?
    • By Aamir77
      Hi,
      Facing problem in putting the recessed lights on a slab made under the ceiling though tried to adjust the offset from the ceiling but failed. Help!
    • By gdesignbuild
      I am just working on a masonry garage design, and have been held up trying to figure out some details. One is for steel lintels that I am putting over the openings. The closest thing that you can use as a header type is a steel-box but I will be using steel angle. The header column shows the dimensions including the length of your lintel but only gives 1.5" on each side of the opening. Is anyone familiar with a way that I can change this to more? Otherwise, I will just remove that column and leave a note in the comments.
      Second issue: When you pull your cross sections from a CMU building, it shows your trusses sitting right on the block. For now I have manually drawn my plate in with an anchor but I was curious if there is a way to do this as well?
    • By olivia222
      I am a new user, and am working on my first multi level dwelling. I know how to create a ground floor foundation, but want to create mid floor slabs for the levels above. I have tried a few things but nothing will appear in cross section as a solid obvious object. It will be a timber structure, but I dont want to indicate that at this stage, just a solid floor.
    • By mbdesigns
      How do I fix this situation where the slab is showing through my foundation wall?
