sputnik27 Posted April 3, 2014 Share Posted April 3, 2014 Just updated to X6. Trying to create a new layout for sheet A type (8 1/2 x 11) not having any luck Link to comment Share on other sites More sharing options...
Gawdzira Posted April 3, 2014 Share Posted April 3, 2014 Could you be a little more specific about what is troubling you? Link to comment Share on other sites More sharing options...
sputnik27 Posted April 3, 2014 Author Share Posted April 3, 2014 in X5, I could create a new layout, by going to the new layout tab, go to print page set up, and select by sheet size. in X6 if I go to new layout tab a default sheet and border appears, I can not change the default sheet size Link to comment Share on other sites More sharing options...
mgabriel Posted April 3, 2014 Share Posted April 3, 2014 Page/sheet setup are under the print menu in layout view. You should be able to adjust everything there. Once everything is to your liking, create a new layout template and save it in the template folder. You can then select the newly created template as a default. Finally, in the future you can just create the new layout and your smaller sheet size with appropriate layout borders and such automagically appear. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 3, 2014 Share Posted April 3, 2014 As Mike said, here are some pictures to illustrate: Pic one shows the layers I have set up for the various sheet sizes. I turn off the 8x11 or 11x17 layers for the full size sheet. I can leave the full size sheet info on all the time since if I am setting the sheet size smaller that info is out of print range. If I want to set up a drawing for 8.5x11 I just change the sheet size in File-> Print-> Drawing Sheet Set UP Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 3, 2014 Share Posted April 3, 2014 Some of us have a single Layout Template with all Sheet Sizes. Each sheet size has it's own Annoset/Layerset so it's a simple matter of switching from one size to another. Link to comment Share on other sites More sharing options...
