mrscott Posted July 15, 2015 Share Posted July 15, 2015 I created a curved set of stairs (correctly or not) and when they attached to Railing Wall, one portion is missing. There basically three staircases. One from the ground to the landing where it splits off into two up around the fireplace and on up to the balcony railing. The plan is attached someone would mind taking a look. I also don't like the way the interior stair at working either. They cut into the room behind the staircase and just aren't cooperating. It will make sense when you see them. Thanks for your feedback, Venue 1.zip Link to comment Share on other sites More sharing options...
CJSpud Posted July 16, 2015 Share Posted July 16, 2015 For you interior 3-pc stairs, connect your lower stairs section to your landing and things will start looking better. Actually, move the edge of your landing over to match up with the upper edge of the lower stairs section. Link to comment Share on other sites More sharing options...
CJSpud Posted July 16, 2015 Share Posted July 16, 2015 For the outside 3-pc stairs, you have two doorways side x side on the upper stairs section on the left as you look at the stairs and building. I think you just need to delete the one to the right of the stairs connection to the balcony. Link to comment Share on other sites More sharing options...
ShaneK Posted July 16, 2015 Share Posted July 16, 2015 Your "open below" on 2nd story is not as wide as your stairway. You are a busy man in the layer department, very nice project. PM if you want. Venue 1 Design 2.zip Link to comment Share on other sites More sharing options...
