Door in corner problem?
Larry_Sweeney
I don't know if I'm having a "brain fart" or what, but I can't get this door to move any closer to the corner. I have "Ignore Casing for Opening Resize" checked in Plan Defaults. Without submitting the plan, doe anyone have an idea what's going on? As always, all advice is greatly appreciated.
Perry........Thanks, that was the ticket!  So, does this work the same on an interior door if you have different size casing on each side of the door?  It goes by the largest casing rather that the size of the casing nearest to the inside corner?
