X7 Centering Tool
Paramount
I found some old threads on this but nothing that really answers my questions. Seems there is history to the issues.
See attached. Anyone know what these leader’s defaults are? One is centering to the wall outer layer and one to the inner layer. I had this issue with walls until I changed change select objects auto interior/exterior default setting’s to “interior walls only” but locating doors does not seem to be looking at it?
Graeme, I finally got it to behave the way I wanted. Some weird image shows up to show what part of an odd shaped room it is centering to...When moving the curser around looking for a CL it is difficult to tell what it being used. I read some just use lines but I wanted to know what is going on. Thanks for the reply.
Usually you get the grey centering line but it also shows the Room , wall, whatever it is centering on selected as well , I have my selection colour set to Pink,40% Trans.  ( a Dan Bauman Tip)  which makes it easy to see what the selection is...
