Byyourbuilder Posted May 14, 2015 Share Posted May 14, 2015 I am trying to make a custom window symbol for an eyebrow dormer. I had to make a custom eyebrow roof symbol by its self because chief would not let me put it where it needed to go, all worked fine. Now I am trying to create a custom window symbol. I don't create that many symbols so I am not great at it ,every time I try to isolate the window by shutting off wall layers I loose my window. I am using a chief window that I shaped correctly.. Will or should this work or do I need to make it out of p solids ? THANKS for any and all help Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 14, 2015 Share Posted May 14, 2015 Windows in walls are essentially "children" of the wall. If the wall is not displayed then the window is not displayed either. The only way you can "isolate" the window is by using the "Delete Surface tool" to temporarily hide the wall surfaces. What is your reason for "isolating the window"? Maybe there's another solution. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 14, 2015 Share Posted May 14, 2015 Look at your window in 3d view and use the "Delete surfaces" tool to delete everything but the window, then use the "Convert to symbol" in the Tools /Symbol section, to create a new symbol. Go back to a plan ,and use the "Get last symbol" to place it in your plan, you might want to save the symbol to your lib. for future use also. Joe beat me to it. 1 Link to comment Share on other sites More sharing options...
Byyourbuilder Posted May 14, 2015 Author Share Posted May 14, 2015 Thanks for your tips... I tried your suggestions and after you delete all the surfaces and click onto save as symbol it adds back the deleted wall surface am I doing something wrong? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 14, 2015 Share Posted May 14, 2015 Not Save as Symbol..... Convert to Symbol Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 14, 2015 Share Posted May 14, 2015 We never said" Save -as" anywhere. Link to comment Share on other sites More sharing options...
Bill_Emery Posted May 14, 2015 Share Posted May 14, 2015 Window symbols are a portion of the program that is broken; unless you want a garden window. It might be good to post a picture of what you want to achieve; as it might be better done using a different method. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 14, 2015 Share Posted May 14, 2015 Another option would be to simply "Add the custom shaped Window" to the Library. In the Library preview window it would look like the wall is included but it really isn't. Link to comment Share on other sites More sharing options...
