Ridge Alignment Problem
grsims20
Take a look at this plan. The 3 pink lines are there to help us see the problem. The middle one is drawn vertically down from the center of the gable over the dining room. The other two are copied 12' each direction. The front gable over the entry is defined by the wall I have selected in my screenshot, which is 24' long and aligns perfectly with my guide lines. So why isn't the roof aligned? The baseline for the left roof plane over the entry is 4-1/2" inset from the guide line, whereas the baseline for the right roof plane is directly on the guide line. I have auto rebuild roofs enabled, and all roof pitches match. I tried moving/deleting/disconnecting nearby walls to see if that's driving it, but no dice.
My best guess is that the center of the entry wall is not really aligned with the center of the dining area wall.  I am assuming that you are not using gable lines or roof baseline polylines.  It *might* also have to do with the fact that you have an inside corner and an outside corner for the entry situation but I am not sure if that will affect the gable position.
If you want a proper diagnosis, you should probably post the plan.
@DBCooperI tried to post the plan, but it's over the 14MB limit. But, the end points of the gable portion of the front entry wall are exactly 24' apart, and exactly aligned with the guide lines brought from above. The center guide line is also equally centered over the entry room. Not that it should matter though, since the gable is defined only by the 24' section of the front wall.
16 minutes ago, grsims20 said:
I'm new to Chief
Great to see a new user...I hope you have as much fine working with Chief as I do!
And yes, the roof adjustments you'd like to make are much easier manually than with auto-roofs. I'd delete the existing 2 roof planes in the front and copy/paste/reflect the 2 in the back using the main ridge as the reflecting line. Then, just drag each gable fascia back to the overhang line using the adjacent roof planes for snapping.
This will allow you to keep the front wall as a single, unbroken wall.
I had no problem getting the ridges to align with auto built roofs.  There are lot's of special cases where auto roofs can't do what you need so learning how to build roofs manually is a very useful Chief skill.  I always start with auto built roofs and only switch to manual when I really need to.  Same with most of the other automatic tools.
To post a plan that is too big, you should first see if you can put it into a compressed .zip file.  If it is still too big, you could then try deleting everything from the plan that is not needed, doing a save as, and then putting it into a .zip file.  If it is still too big, you could always post it on the cloud somewhere and then post a link to it.
