grsims20 Posted 38 minutes ago Share Posted 38 minutes ago Take a look at this plan. The 3 pink lines are there to help us see the problem. The middle one is drawn vertically down from the center of the gable over the dining room. The other two are copied 12' each direction. The front gable over the entry is defined by the wall I have selected in my screenshot, which is 24' long and aligns perfectly with my guide lines. So why isn't the roof aligned? The baseline for the left roof plane over the entry is 4-1/2" inset from the guide line, whereas the baseline for the right roof plane is directly on the guide line. I have auto rebuild roofs enabled, and all roof pitches match. I tried moving/deleting/disconnecting nearby walls to see if that's driving it, but no dice. Link to comment Share on other sites More sharing options...
