decorators3
Subject: Creating Terrain for a Multi-House Development from a Topographic Survey — X18
Hi
I've received a topographic survey and DWG file for a proposed residential development involving multiple houses.
I've worked with terrain in Chief Architect Premier X18 before, but not on a project of this scale. I need to recreate the existing sloping terrain, position the proposed houses at their appropriate elevations, and eventually produce realistic renderings showing how the entire development will sit on the property.
The property slopes upward along the road, and the proposed houses will be stepped along the grade, with each successive house approximately 2 feet higher than the previous one.
I've managed to import the DWG into Chief Architect. It appears very similar to the original topographic survey, except that the DWG displays green elevations labelled TOPO and additional yellow numbers. I've also noticed separate layers named TOPO, ELEVATION and MSPOINT.
I'm arranging to speak with the surveyor to clarify what the different numbers represent and whether the DWG contains actual 3D elevation data or simply text labels.
In the meantime, I'd really appreciate some guidance on the best way to approach this in X18.
Would it be better to import the elevation data directly, assuming it's available, or manually enter the surveyed elevation points? And how would you approach positioning multiple houses at different elevations while keeping the terrain as accurate as possible?
Perhaps I'm making this more complicated than it needs to be!
I've attached a cropped screenshot showing some of the elevation numbers for reference.
A special thank-you to those who have assisted me with terrain-related questions in the past. Your patience and guidance have been greatly appreciated, and I have a feeling I'll be calling on your expertise again as this project progresses!
Thanks in advance for any suggestions.
Cheers
Levina
Hi
Cheers
Levina
If you haven't already you should watch these videos to familiarize yourself.  It's a great resource.
https://www.chiefarchitect.com/videos/playlists/101/terrain-and-site-plans.html
