ChristianA Posted November 9 Share Posted November 9 In x17, the fill for concrete walls and slabs when you used the auto detail feature followed the wall type and floor structure fill setting. It's seems as though in x18, the auto detail feature ignores the these settings and makes it a concrete fill with a 2" scale. Am I missing something or is there another place that this can be changed? 1 Link to comment Share on other sites More sharing options...
Chrizoo Posted November 13 Share Posted November 13 Hi Christian, I am experiencing a very similar issue after moving from X17 to X18. In X17, I had my concrete fills set to black concrete hatching on a green background, and Auto Detail produced that appearance automatically. With the same template in X18, the concrete fill I checked in Floor Structure still appears green, but running Auto Detail in a new cross section produces a white background. On one generated CAD polyline, we found that the background colour source was set to Use Background Color. Changing it to Custom Color and selecting green corrected that individual shape, but that does not resolve the automatic behaviour for future Auto Detail runs. The generated concrete pattern spacing was 50 mm. Has anyone found a setting or a template migration issue that explains this? I would appreciate any guidance on preserving the assigned concrete fills automatically in X18 rather than editing each generated shape manually. Chief Architect Premier X18, build 28.2.1.14, Windows. Thank you for raising this question. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 13 Share Posted November 13 Have either of you reported this to Chief Support? Link to comment Share on other sites More sharing options...
Chrizoo Posted November 13 Share Posted November 13 Hi Joe, not yet. I wanted to check with the community first in case this is a setting I have missed or someone has already found a workaround in X18. I would appreciate any suggestions from others who have experienced this. Thank you for the suggestion. Link to comment Share on other sites More sharing options...
ChristianA Posted November 13 Author Share Posted November 13 52 minutes ago, Joe_Carrick said: Have either of you reported this to Chief Support? Not yet, as I was giving the forum a chance to educate me. Since I haven't received any info from users, I will report this. Link to comment Share on other sites More sharing options...
robdyck Posted November 13 Share Posted November 13 I have also noticed that all concrete objects now fill using Chief's embedded concrete fill pattern. My settings are ignored for concrete walls and floor structures. For basements I had control over the wall and floor, but never the footing fill. For me, this is not a problem because I always replaced Chief's fill pattern for the footing with my own, which was my same choice for concrete walls and slabs. I have that fill pattern in my library with a tool linked to it. When I use the spray fill tool, I just ensure it is in Floor mode and then it replaces all matching fills at one time. 1 Link to comment Share on other sites More sharing options...
ChristianA Posted November 16 Author Share Posted November 16 I heard back from Chief support today and here is their response: "Good Morning, Thank you for contacting Chief Architect technical support. I was able to reproduce this behavior on my end. In X17 and prior the fill would follow the Fill Style I had specified for my concrete, but in X18 it seems to be hardlocked to the standard concrete fill when using Auto Detail. I have reported this to our development team to hopefully have this addressed in a future update. Thank you for bringing this to our attention! Please let me know if you have any further questions. Thank you, Tyler" 1 Link to comment Share on other sites More sharing options...
