Beazley_Home Posted August 19 Share Posted August 19 Why does the trim not reach the top of the stairwell unless there is a wall all the way to the stairs' edge? I have previously forced it when the stairs end in a room by adding an invisible wall under the stairs’ edge, but I cannot do that in all situations. Under these stairs is a hallway; I can't have a random wall within a hall or show an invisible wall on the plans. Is there a setting that I have missed that would fix this? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 19 Share Posted August 19 How would the trim be installed if there wasn't a wall to attach it to? Link to comment Share on other sites More sharing options...
Beazley_Home Posted August 20 Author Share Posted August 20 16 hours ago, Joe_Carrick said: How would the trim be installed if there wasn't a wall to attach it to? There is a wall, see images. Or are you saying that Chief doesn't consider the space between the floors to be a part of a wall or something to attach the trim too? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 20 Share Posted August 20 12 minutes ago, Beazley_Home said: There is a wall, see images. Or are you saying that Chief doesn't consider the space between the floors to be a part of a wall or something to attach the trim too? Can you post the plan? That's the only way to figure out what's wrong. Link to comment Share on other sites More sharing options...
Beazley_Home Posted August 20 Author Share Posted August 20 20 minutes ago, Joe_Carrick said: Can you post the plan? That's the only way to figure out what's wrong. Savannah-III.zip Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 20 Share Posted August 20 18 hours ago, Beazley_Home said: I can't have a random wall within a hall Why not? 18 hours ago, Beazley_Home said: or show an invisible wall on the plans. Just cut the walls and place the extension segments needed for the trim, that you don't want to see, on the Walls, Invisible layer, and turn it off. Or create a custom layer just for them if you want more control. Link to comment Share on other sites More sharing options...
