Stairs Trim / Railing
Beazley_Home
Why does the trim not reach the top of the stairwell unless there is a wall all the way to the stairs' edge?
I have previously forced it when the stairs end in a room by adding an invisible wall under the stairs’ edge, but I cannot do that in all situations. Under these stairs is a hallway; I can't have a random wall within a hall or show an invisible wall on the plans.
Is there a setting that I have missed that would fix this?
16 hours ago, Joe_Carrick said:
How would the trim be installed if there wasn't a wall to attach it to?
There is a wall, see images.
Or are you saying that Chief doesn't consider the space between the floors to be a part of a wall or something to attach the trim too?
Can you post the plan?  That's the only way to figure out what's wrong.
Why not?
Just cut the walls and place the extension segments needed for the trim, that you don't want to see, on the Walls, Invisible layer, and turn it off. Or create a custom layer just for them if you want more control.
1830374519_Screenshot2026-08-20at10_12_03AM.thumb.png.0b16336c0a4fa6a4d3d9b053db6582c2.png
2049359090_Screenshot2026-08-20at10_11_39AM.thumb.png.a91afe4c895f621d790252a7365d33ac.png
178848317_Screenshot2026-08-20at10_12_23AM.thumb.png.e3f9c3c7a5d4ee6f2609f1a7c1821edb.png
