PitMan71 Posted Thursday at 10:08 PM Share Posted Thursday at 10:08 PM Anyone know why the frieze wont generate on this roof sections? Also, side question, is there a simple way to do a roof like this with auto generate roofs on? Thanks 260031-XX - Dog Ear Roof.zip Link to comment Share on other sites More sharing options...
ValleyGuy Posted Thursday at 10:17 PM Share Posted Thursday at 10:17 PM Are there little sections of attic walls under the slope? They might need to have the frieze board turned on. I normally build all my roofs manually, sorry no help on your side quest. 1 Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted Friday at 01:15 PM Solution Share Posted Friday at 01:15 PM 15 hours ago, PitMan71 said: Anyone know why the frieze wont generate on this roof sections? Hi Shane. Yeah I've seen that a lot on auto generated roof trim. Not sure why it happens, but something I do that often works is just selecting the errant trim, grabbing one of the end handles and moving it slightly then letting go. In your case, doing this forced both sides to generate. Selecting that trim edge is tricky sometimes but look for it on the Roofs, Trim layer. Might have to do that more than once as you work on the model. It's a Chief Thang!™ 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted Saturday at 02:06 PM Author Share Posted Saturday at 02:06 PM On 8/14/2026 at 8:15 AM, Chrisb222 said: Hi Shane. Yeah I've seen that a lot on auto generated roof trim. Not sure why it happens, but something I do that often works is just selecting the errant trim, grabbing one of the end handles and moving it slightly then letting go. In your case, doing this forced both sides to generate. Selecting that trim edge is tricky sometimes but look for it on the Roofs, Trim layer. Might have to do that more than once as you work on the model. This fixed it.... Or its a good work around. Thanks for the reminder.... Seems like i have done this before. Link to comment Share on other sites More sharing options...
