Arunc0108 Posted yesterday at 08:54 AM Share Posted yesterday at 08:54 AM Hello, I'm working in Chief Architect X12 and I'm having trouble modeling a basement entrance correctly. I have an existing structure, and I need to recreate it exactly as shown in my reference photos. The area causing the issue is marked in red on both the reference images and my Chief Architect screenshot. I Want to create the basement exterior entrance exactly like the reference , door placement at the basement level. However, I'm having difficulty placing and configuring the basement door correctly while maintaining the proper stair alignment. For reference, I've attached: 2 photos of the actual structure with the problem area highlighted in red. 1 screenshot from my Chief Architect X12 model, also with the same area marked in red, showing where I'm getting stuck. Could someone please explain the correct workflow or the best w ay to model this type of basement entrance in Chief Architect X12? Any step-by-step guidance, suggestions, or example files would be greatly appreciated. Link to comment Share on other sites More sharing options...
MPDesign Posted 21 hours ago Share Posted 21 hours ago Try making the space (room type) open below, then make a room on foundation level. Use foundation wall type. Place door on foundation level. Make stairs from basement to terrain. Hope that helps. Link to comment Share on other sites More sharing options...
DBCooper Posted 19 hours ago Share Posted 19 hours ago See if this tech article about making a split level entry helps: https://www.homedesignersoftware.com/support/article/KB-00269/creating-a-split-level-entry-with-a-landing.html Link to comment Share on other sites More sharing options...
