Need Help Creating a Basement Entrance in Chief Architect X12
Arunc0108
Hello,
I'm working in Chief Architect X12 and I'm having trouble modeling a basement entrance correctly.
I have an existing structure, and I need to recreate it exactly as shown in my reference photos. The area causing the issue is marked in red on both the reference images and my Chief Architect screenshot.
I Want to create the basement exterior entrance exactly like the reference , door placement at the basement level. However, I'm having difficulty placing and configuring the basement door correctly while maintaining the proper stair alignment.
For reference, I've attached:
2 photos of the actual structure with the problem area highlighted in red.
1 screenshot from my Chief Architect X12 model, also with the same area marked in red, showing where I'm getting stuck.
Could someone please explain the correct workflow or the best w ay to model this type of basement entrance in Chief Architect X12? Any step-by-step guidance, suggestions, or example files would be greatly appreciated.
Try making the space (room type) open below,  then make a room on foundation level. Use foundation wall type.
Place door on foundation level. Make stairs from basement to terrain.
Hope that helps.
