Build Roof Dialogue - Custom Ridge Cap - Vertical Offset
ComputerMaster86
1 hour ago, DBCooper said:
I think it is only rounding the display in the dialog to the nearest 1/16".  Use the number style button and change the display to decimal inches and you should see the actual values.
Sorry to say but that doesn't seem to be true.  It's indeed rounding the value I typed in.  In other dialogue boxes Chief will round the display without rounding the value.  For both the vertical and horizontal offset for molding profiles Chief seems to be rounding the actual value.
I realized this after typing in values that used 32nd's and 64th's of an inch and my profile would move more than I wanted it to or wouldn't move at all, compared to the last value I typed in..  It was driving be batty.  Then I realized it was only moving in increments of 1/16th's of an inch.
Edited by ComputerMaster86
