Ed_Orum Posted Monday at 07:16 PM Share Posted Monday at 07:16 PM Hello again, I suppose I should have paid more attention when I started using Chief back in (I think) 1998. I have multiple lines where the ends touch each other. I would like to connect them so they make a closed polyline. I have the "connect cad segments" box checked, but after I select them all, they just don't want to join up with each other. Can this be done or am I misundersting the definition of "connect CAD segments"? Thanks in advance, Lane Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted Monday at 07:36 PM Solution Share Posted Monday at 07:36 PM 16 minutes ago, Ed_Orum said: I have multiple lines where the ends touch each other. I would like to connect them so they make a closed polyline. If the ends are currently touching each other, click on one of the lines to select it, then click again on the end point, and they should connect. If some of the ends aren't touching where you cannot make a closed polyline without changing the line's size or angle, that's a different situation with a different process... Link to comment Share on other sites More sharing options...
robdyck Posted Monday at 07:38 PM Share Posted Monday at 07:38 PM (edited) All of those lines would need to have the same properties to join (layer, line weight, line style, color). Edited Monday at 07:39 PM by robdyck Link to comment Share on other sites More sharing options...
Ed_Orum Posted Monday at 08:14 PM Author Share Posted Monday at 08:14 PM Thanks, that does it! 1 Link to comment Share on other sites More sharing options...
