SHCanada2 Posted June 6 Share Posted June 6 (edited) I'm trying to do what I thought would be relatively simple. Change the gable to a dutch gable that looks like: so the roofline is over the top plate I have this, where the lower wall is broken to delineate the gable going across: but if I change the 3 walls (broken, top, right lower) to duthc gable and set the in from baseline at 24" I get: it looks like this: the one not seen looks good, but it looks like it just ignored the hip directive on the wall to the right of the broken wall Residential Template - Copy 1.plan Edited June 6 by SHCanada2 Link to comment Share on other sites More sharing options...
Mark3D Posted June 7 Share Posted June 7 Have you watched this Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 7 Author Share Posted June 7 (edited) 1 hour ago, Mark3D said: Have you watched this just did, but I realize I could build it manually, and this video shows a good way to do it compared to what I would have tried. But is there no automatic way to do it? and why is the program dutch gabling the whole side when I only told it to do the left portion? If I make that wall back to a gable, then the front garage is correctly built as dutch gable so it has something to do with that split wall Edited June 7 by SHCanada2 Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 7 Author Share Posted June 7 (edited) well..found this in home designer forum which is exactly what I am trying to do L-shaped Dutch gable roof - Q&A - HomeTalk Forum CA staff state: "Home Designer Pro should give you the tools to make that happen. However, you can get really close in Home Designer Suite by using the following technique:" I'm not sure if the "tools" means manually or automatically I tried the work around in this thread and could not get it to work Edited June 7 by SHCanada2 Link to comment Share on other sites More sharing options...
