ACADuser Posted May 4 Share Posted May 4 I'm attempting to "select similar" while using the LINE tool and holding the shift key and the "Select Intersection Objects" is active. The problem is that it selects Text & leaders too! Is this a bug? Link to comment Share on other sites More sharing options...
jorgearaya Posted May 4 Share Posted May 4 Submit it to support. For now, you can select one line and right click then choose the marquee select similar tool and drag your selection, it should omit the text. Link to comment Share on other sites More sharing options...
DBCooper Posted May 5 Share Posted May 5 It makes some sense that it selects leader lines since they are really just lines. It does not make sense to select the text though. I also noticed that it only selects rich text and not plain text. I think it has always done this but you should still report it as a bug. Link to comment Share on other sites More sharing options...
ACADuser Posted May 5 Author Share Posted May 5 19 hours ago, jorgearaya said: Submit it to support. For now, you can select one line and right click then choose the marquee select similar tool and drag your selection, it should omit the text. That method does work. Thanks I did a bug report. Link to comment Share on other sites More sharing options...
