cjanderson66 Posted 1 hour ago Share Posted 1 hour ago I am trying to create a deck rail like this with a 1X4 top and bottom rail w/ 2X2 Balusters in between. Does anyone have an idea of how to create this? Link to comment Share on other sites More sharing options...
JKEdmo Posted 29 minutes ago Share Posted 29 minutes ago 42 minutes ago, cjanderson66 said: I am trying to create a deck rail like this with a 1X4 top and bottom rail w/ 2X2 Balusters in between. Does anyone have an idea of how to create this? Christopher, I'm by no means an expert on this but I gave it a quick try. Might point you in the right direction at least. I drew up the polyline profile for the top built-up rail and then added to library. You can then replace the standard top rail with this library object. By sizing it right and messing around with the vertical offset, seems like you could make it work. I assume this can be done for the bottom rail too. Jim Link to comment Share on other sites More sharing options...
