DECK RAILING
cjanderson66
42 minutes ago, cjanderson66 said:
I am trying to create a deck rail like this with a 1X4 top and bottom rail w/ 2X2 Balusters in between.  Does anyone have an idea of how to create this?
Christopher,
I'm by no means an expert on this but I gave it a quick try.  Might point you in the right direction at least.
I drew up the polyline profile for the top built-up rail and then added to library.  You can then replace the standard top rail with this library object.  By sizing it right and messing around with the vertical offset, seems like you could make it work.  I assume this can be done for the bottom rail too.
Jim
36 minutes ago, JKEdmo said:
Christopher,
Jim
Jim,
That was a great help and sent me in the right direction.
Thank you
Chris
