DesignTech Posted Monday at 03:05 PM Share Posted Monday at 03:05 PM Does anybody know how to re-dock the library and project browsers? i accidentally pulled over to another monitor and now it always shows up there instead of docked in the default location. Brian Chief Architect Premier x13 Link to comment Share on other sites More sharing options...
ChiefTylerL Posted Monday at 03:08 PM Share Posted Monday at 03:08 PM Hello @DesignTech, You can reset the position of your side windows by going to Edit> Preferences (Chief Architect> Preferences if you're on a Mac), going to Reset Options, choosing Reset Side Windows, and then closing/opening the program. I hope this helps! Link to comment Share on other sites More sharing options...
Chrisb222 Posted Monday at 03:17 PM Share Posted Monday at 03:17 PM 10 minutes ago, DesignTech said: Does anybody know how to re-dock the library and project browsers? You can also just double-click on the browser's title bar, at least on the Mac. Link to comment Share on other sites More sharing options...
Solution DesignTech Posted 17 hours ago Author Solution Share Posted 17 hours ago Thanks for the advice guys. although I'm not on a MAC, It worked after I closed out and re-opened. Guess I need to update my signature ;-) Brian Chief Architect Premier x17 PC Link to comment Share on other sites More sharing options...
DBCooper Posted 11 hours ago Share Posted 11 hours ago I think Tyler's post above should be marked as the "solution" since he told you how to fix it. You should be able to change it since you started the thread. Also, if you are going to update your signature, you might want only one. Right now it looks like you have two signatures, one saying you are using X13 and one saying X17. Link to comment Share on other sites More sharing options...
