How to re-dock the library and project browsers
DesignTech
Go to solution Solved by DesignTech,
Does anybody know how to re-dock the library and project browsers? i accidentally pulled over to another monitor and now it always shows up there instead of docked in the default location.
Brian
Chief Architect Premier x13
  • Solution
Thanks for the advice guys. although I'm not on a MAC, It worked after I closed out and re-opened.
Guess I need to update my signature ;-)
Brian
Chief Architect Premier x17
PC
I think Tyler's post above should be marked as the "solution" since he told you how to fix it.  You should be able to change it since you started the thread.
Also, if you are going to update your signature, you might want only one.  Right now it looks like you have two signatures, one saying you are using X13 and one saying X17.
